Buy a H440 and cram all of the cables carelessly inside the power supply cover.
Honestly this is the easiest way, but for this I personally like the Air 540 (has a huge separate compartment)
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
Like Octavialicious said, consider dual-chamber cases like the Corsair Air series. (Air 540, Air 240)
They give you an absurd amount of space hidden away from the "visible" chamber where you can stuff all your cables without really worrying about doing a 'good' job.
For everything else, use zip ties and/or twist ties.
