Couldnt quite find a place in the forum section for this so guess this'll do.
Trying to find one, gonna be hooking up 4 or so to it, so far these are my choices, http://www.newegg.com/Product/Product.aspx?Item=N82E16811999309 and http://www.newegg.com/Product/Product.aspx?Item=N82E16811990008&cm_re=fan_port-_-11-990-008-_-Product
Suggestions?
https://linustechtips.com/topic/508703-fan-controller-hub/
Suggestions?
If you have PWM fans and your wanting to hook them up as a group to control on the motherboard that SIlverstone splitter will work, Swiftech also makes one of those. The Deepcool fan controller can only do 3 pin DC volt control however.
What fans are you using exactly and are you looking to achieve.
https://linustechtips.com/topic/508703-fan-controller-hub/#findComment-6785834
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181046  as well as 5 of the 140mm variants for my AIO water cooler and control over all of the fans from one point in my machine.
https://linustechtips.com/topic/508703-fan-controller-hub/#findComment-6785967
If you want to have all the fans be at the same speed and control something else like the NZXT Grid+ would be a good option that lets you use software to set temperature based fan curves, the Grdi +V2 allows for individual control and temperature curves of each connected fan:
https://www.nzxt.com/products/GRID-Plus
https://www.nzxt.com/products/GRID-Plus-v2
https://linustechtips.com/topic/508703-fan-controller-hub/#findComment-6786019
