So, Christmas is near and I am building a computer because my GT430 i3-2100 computer is crap now, although it runs BF4 30fps on low 768p.. Now, I need a better computer. What do you guys think about the $800 budget gaming PC? Any suggestions?
http://pcpartpicker.com/p/V3Bp7P
PCPartPicker part list: http://pcpartpicker.com/p/V3Bp7P
Price breakdown by merchant: http://pcpartpicker.com/p/V3Bp7P/by_merchant/
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($89.99 @ Micro Center)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.98 @ OutletPC)
Motherboard: Asus M5A78L-M/USB3 Micro ATX AM3+ Motherboard ($45.98 @ Newegg)
Memory: Corsair XMS3 8GB (2 x 4GB) DDR3-1333 Memory ($36.99 @ Micro Center)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.98 @ OutletPC)
Video Card: PowerColor Radeon R9 280X 3GB TurboDuo Video Card ($183.98 @ Newegg)
Case: Cooler Master HAF 912 ATX Mid Tower Case ($39.99 @ Newegg)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($52.98 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($17.99 @ SuperBiiz)
Sound Card: Creative Labs Audigy SE 24-bit 96 KHz Sound Card ($21.99 @ SuperBiiz)
Monitor: BenQ GW2255 60Hz 21.5" Monitor ($119.99 @ Amazon)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse ($21.98 @ Newegg)
Headphones: Sennheiser HD 219s Headset (Purchased For $0.00)
Total: $706.82
Generated by PCPartPicker 2015-12-19 00:37 EST-0500
https://linustechtips.com/topic/508344-xmas-build/
Check this monitor out, it's 60hz 4MS and IPS http://www.amazon.com/Acer-R240HY-bidx-23-8-Inch-Widescreen/dp/B0148NNKTC/ref=sr_1_2?s=pc&ie=UTF8&qid=1450503844&sr=1-2&keywords=acer only $130 though it has some light bleed issues sorta it has small bezels.
i5 4590 @ Stock, XFX R9 290!, HyperX Beast 4x8GB  @1600, 850 EVO 120gb, WD Caviar Blue 1TB, , Asrock H97m Pro 4 , Fractal Design Define R4, Windows 10
https://linustechtips.com/topic/508344-xmas-build/#findComment-6782050
Total: $706.82
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.99 @ SuperBiiz)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($67.99 @ SuperBiiz)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  ($202.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($53.99 @ SuperBiiz)
Monitor: Acer H226HQLbid 60Hz 21.5" Monitor  ($99.00 @ Newegg)
Total: $729.81
Generated by PCPartPicker 2015-12-19 00:44 EST-0500
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/508344-xmas-build/#findComment-6782051
Please replace that I5 4460 with the Intel i5 4590 from Jet.com it's $20 cheaper
https://linustechtips.com/topic/508344-xmas-build/#findComment-6782061
That's assuming that the 4590 would be his first purchase at Jet.  Then the discount will be applied.
https://linustechtips.com/topic/508344-xmas-build/#findComment-6782065
It would be. Jet is fairly new so I'm like 100% sure it would be his first purchase, regardless it's still only $10-15 more otherwise without the discount.
https://linustechtips.com/topic/508344-xmas-build/#findComment-6782070
