I've tried doing searches on these topics and not find what I'm looking for.
1.  How do you migrate custom game profiles when upgrading from one version of crimson to the next?
If I already have crimson 15.11 or 15.11.1, and I've taken some time to setup some custom profiles for a few games, how do I migrate those profiles over to 15.12? Meaning, I don't want to have to go through the trouble of setting up those profiles again after installing 15.12. If anyone has a link or some info, please share.  The option to upgrade from within Crimson does not work.  I've tried with both versions to go to 15.12 and both keep telling me i'm up-to-date, even though i'm not.
Is there a hidden setting I can't find that saves or exports these profiles?  I mean, the only way I can actually do the upgrade is to uninstall 15.11/15.11.1, reboot, then install 15.12.  If there isn't a hidden setting(or a very obvious one I can't see), are there application files that can be copy/pasted that would do the trick?  If there isn't a way, then that is fine, I'll just have to keep notes of what profiles I've changed and what was changed in said profiles.
2.  If the 'upgrade' feature within crimson does not work and you want to upgrade to the next version, is it necessary to run the AMD uninstall clean utility before installing a newer version of crimson?
Rock On!
https://linustechtips.com/topic/508146-crimson-help-needed/
My driver updated automatically. My game profiles are all still there. My profiles from CCC from quite a while ago are all still there as well. Maybe they store them somewhere separate to the driver.
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/508146-crimson-help-needed/#findComment-6779984
How long was the latest driver available before Crimson on your PC decided to automatically upgrade itself?
Rock On!
https://linustechtips.com/topic/508146-crimson-help-needed/#findComment-6780048
Well my computer did the windows 10 "Update" yesterday. I'm not going to lie I was a little lost when it did an update the same way it does a full OS upgrade. But it hasn't affected any of my catalyst/crimson profiles. Not entirely sure when it did the driver update, But it is up to date now.
https://linustechtips.com/topic/508146-crimson-help-needed/#findComment-6780115
