Hi everyone,
I have an acer 5739G, it's original battery doesn't go over 5% even after many "full-charge-discharge cycles".
Few days ago I got a new Lavolta supported battery and it has the very same problem.
This is what I did:
-got the new battery, put it in the laptop (turned off) and let it charge for the night.
-then un-plugged and turned the laptop on: it said the remaining battery was 6% but I didn't worry, the battery is supposed to arrive fully discherged; I let the laptop drain the battery until it turned off
-re-charged it for the night once more and a few hours in the morning. when I turned it on (unplugged), battery level was still 6% (?!?!?!).
-drained the battery once more; but this time re-charged it while turned on:
--when it got at 6% the charging light turned from orange (charging) to blue (full) and the win10 icon says: "6%, connected but not charging"
I run a win10 battery report and it says:
MANUFACTURER SIMPLO SERIAL NUMBER 2455 CHEMISTRY LION DESIGN CAPACITY 48 mWh FULL CHARGE CAPACITY
726 mWh
which means that either the battery has a lower capacity (64.4 mAh) (which I duobt) or it doesn't fully charge.
Here is the website I used to convert capacities:
https://milliamps-watts.appspot.com/
Does anyone have an idea about what's happening?
ohh, here's some more data that may help:
SYSTEM PRODUCT NAME Acer Aspire 5739G BIOS V0.3306 08/24/2009 OS BUILD 10586.17.amd64fre.th2_release.151121-230
Thanks for support.
Have a great day.
https://linustechtips.com/topic/507276-max-battery-level-6/
It's L-Ion? You don't need to do full charge/full drain cycles, that actually can damage L-Ion batteries.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/507276-max-battery-level-6/#findComment-6770022
this is what the instructions on the box say
The instructions always say that. You only had to (before, with non L-Ion batteries) fully charge and discharge it once to calibrate the battery, but with new L-Ion batteries the process happens at the factory, and your laptop will automatically know what to do with the battery. It's not recommended to full charge/full discharge with L-Ion because again, it damages the battery after a while.
The Laptop:
https://linustechtips.com/topic/507276-max-battery-level-6/#findComment-6770452
