PSU Electronial buzz sound
Metro
Hello
I got a EVGA 1600w T2 and it seems there is coil whine, unsure though. It sounds like an electrical buzz. Sounds like it is near the plug of the PSU. It happens during idle and load. It is a new PSU
Thanks
GPU[Two GTX 980ti Lightnings overclocked]-CPU[Core i7 5930K, 4.4Ghz]-Motherboard[MSI X99 Godlike]-Case[Corsair 780t Black]-RAM[32GB Corsair Dominator 3000Mhz Light bars]-Storage[samsung 950 Pro 512GB, Samsung 850 Pro 1TB and Samsung 850 Pro 512GB]-CPU Cooler[EK Predator 360mm]-PSU[EVGA 1600w T2 Individual cables Red]-Monitor[ASUS PG348Q]-Keyboard[Corsair K70 Red]-Mouse[Corsair M65 RGB]-Headset[sennheiser G4me one]-Case Fans[beQuiet Silent Wings 2]
Yep, that will be coil whine. It's annoying, but it's not a sign of any problems other than maybe minor quality control issues.
If it bothers you, RMA it. If not, it'll work fine.
The Cheap SFF Wonder -- Turning a Core 2 Duo SFF machine into a useful member of computer society!
i5 3570 -- AS.Rock Z77 Pro3 -- 12GB DDR3 -- R9 380X -- 840Evo 500GB/1TB HDD
I speak the honest truth with a bit of snark mixed in. I'm sorry if it doesn't line up with your beliefs.
Yeah, it is basically silent even during idle with ECO mode on, only hear it if you put your ear next to the PSU, just wanted to make sure it was coil whine.
Unplug that main cord, and insert it firmly.
Since you told that it's near PSU plug.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
I tried, still not working.
that build doe.
Maybe change the fan?
is the cable bend?
Change the fan of the PSU?
Yeah, the cable is not completely straight, however it is not really bent
Prepare it for RMA, just to be safe.
You have one hell of a rig there! Beasty one!  :D
It is so quiet though, is it worth a RMA?
Yeah, I guess. Because it won't bother you anymore, if you did the RMA.
Can it get worse or will it stay at the same noise level
I'm not sure about that.
It's an Electrical Component. Could go crazy or Stay on for 100 years.
As I told you before, You can RMA it. Their Customer Support is great. I'd RMA it, if I were you! :)
