I just got myself an i7 4770k, and it was watercooled, but my watercooler just died on me (not sure why, buying a new one shortly, nothing in my PC was damaged)
So im using the stock cooler for the moment, I want to OC it to 4.0Ghz for now,
Literally never done it before on any CPU, would it be safe on the cooler? How do i do it? Any video references?
Thanks
https://linustechtips.com/topic/506519-advice-on-overclocking/
Thanks
Just no, lol. Get a replacement cooler and then overclock.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/506519-advice-on-overclocking/#findComment-6760503
It will run hot at stock speed with that cooler. You have no head room. Wait for the upgrade
EVGA SR-2 / 2x Intel Xeon X5675 4.4Ghz OC / 24GB EEC 1800Mhz OC/ AMD RX570 / Enermax Evoliution 1050W / Main RAID 0: 2x256GB 840EVO SSD / BackUp(1) Raid 5: 3x2TB WD HDD / BackUp(2) 8x2TB / Dell U2412M / Dell U2312HM
https://linustechtips.com/topic/506519-advice-on-overclocking/#findComment-6760578
No, 1rst gen haswell is notorious for being horrible at overclocking. Wait for another cooler.
Also if you plan on doing any decent overclocking, i would delid ( at your own risk)
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/506519-advice-on-overclocking/#findComment-6760623
