Internet speed up connection using cmd?
Solved by Enderman,
i googled each of the commands
nothing will harm your PC
it just seems like minor tweaks to the way networking is handled by windows, people say they dont notice any improvement
all the commands are reversible (aka you can set them back to default) so if you want to try it there should be no risk
but i doubt it will make any difference to the connection
