All Prices and Lights aside, is the actual surface of the razer firefly good?
"The ability to destroy a planet is insignificant, next to the power of the force"
Kirito (Main Build):
CPU Intel Core i5-6600k OC'd @ 4.6 GHz Motherboard ASUS Z170-AR RAM 16GB Corsair Vengeance LPX 2400 GPU ASUS STRIX 1070 Case Phanteks Enthoo Pro Storage Samsung 850 EVO 250GB, WD Green 2TB & Travelstar 1TB PSU Corsair CS550M Cooling Corsair H110i GT Keyboard Razer Blackwidow Chroma Mouse Razer Naga Epic Chroma Sound Sennheiser HD280 Pro OS Windows 10
Asuna (My Laptop): Razer Blade Stealth
CPU Intel Core i5-7200U w/ Hyperthreading RAM 8GB Hardwired into the system GPU I N T E G R A T E D   G R A P H I C S  Storage Samsung 960 EVO m.2 120GB Cooling Fans yo Keyboard Razer Blackwidow Chroma Mouse Razer Naga Epic Chroma Sound Sennheiser HD280 Pro OS Windows 10
Yui (My mini server):
TBD
https://linustechtips.com/topic/506115-razer-firefly-quality/
xD
TBD
https://linustechtips.com/topic/506115-razer-firefly-quality/#findComment-6755788
Topkek
TBD
https://linustechtips.com/topic/506115-razer-firefly-quality/#findComment-6755789
well.. i'm gonna start by saying i have no first hand experience with razer products, nor do i use mousepads.
but think of it like this:
you pay roughly €70 for a mousepad with LEDs, a usb hub, and some other stuff.
no matter how well its quality for money is, you'll always get better value when going for a product where the entire budget went into its main purpose: a surface to use your mouse.
i can go around the corner to the diy store and buy a sheet of whatever i want my mousepad to be, and it'll be a fraction of the cost, while being better quality.
https://linustechtips.com/topic/506115-razer-firefly-quality/#findComment-6755794
no mater how well its quality for money is, you'll always get better value when going for a product where the entire budget went into its main purpose: a surface to use your mouse.
I understand that you are trying to be helpful and I appreciate it, but I'm not asking about what kind of deal you can get or what you can get thats better, I'm just asking about the quality of the mousepad itself.
TBD
https://linustechtips.com/topic/506115-razer-firefly-quality/#findComment-6755819
