I need help testing a graphics card
I have an old amd x1300 and I want to test it in a system to see if it works. how do I go about doing this? I have a AMD 6850 in there do i just unplug that and plug this one in and boot? or do I need to install the drivers first? please help.
Ps. this is not going to replace my 6850 i only want to see if it works
Current system CPU: Intel 4670k    MotherBoard: Asus z87-C   RAM: 12GB 1333mhz GPU: Sapphire AMD r9 290    Case: Corsair 200R    Storage: 250gb Sandisk SSD, 1tb segate barracuda HDD PSU: Corsair RM 850 Cooling: Corsair h100i No over clock
https://linustechtips.com/topic/5058-i-need-help-testing-a-graphics-card/
Yup, just take out the old card and plug this one in. Windows should automatically get the drivers.
What version X1300 do you have? Some X1300 have a PCI interface which will not work with the PCI E slot your 6850 is plugged into.
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
Yes pulling the GPU and putting the one in should work. When you are in your OS, download the latest drivers for your GPU via internet and install it.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
