Good USB hub
Go to solution Solved by W-L,
Hey so my current USB hub will allow everything to be plugged into it but wont relay all of the info to my pc i.e. some peripherals wont register as plugged in, the reason I am doing this is to clean up my desk and it needs to have at least 5 ports. Thanks a ton!
Depending what you need Anker makes a variety of USB hubs:
http://www.ianker.com/USB-Data-Hubs/category-c11-s1
https://linustechtips.com/topic/505729-good-usb-hub/#findComment-6750214
