Wide Angle Lens for Self-Shooting
snip
Ahh those kind of converters, I avoid using them.
Stop down your lens to a smaller aperture and you will find a sweet spot for improved sharpness. Usually it's somewhere between f/4 and f/11. Also, you're shooting video which has motion. It's never going be as sharp as a still photo. If you need more lights, get some.
I'm not telling you not to get one, I'm advising you to find a better solution than resorting to using a wide angle lens because you want to keep the camera close at hand. Which will likely introduce distortions. I never said don't get the Tokina, if you buy it use the 16mm end. The Tokina has a better IQ than the Rokinon. The advantage of the Rokinon is that it is a cine lens, so the focusing wheel on the lens has a wider turn arc than stills photo lenses. This will give you more precise control over manual focus.
Both lenses will produce similar IQ for video, the Tokina will however produce better IQ for stills photos.
Here's a video shot with a D800, which has a better image quality than many DSLR's for video and one of the best IQ for a stills camera. Yet it still doesn't look as sharp as a still photo.
