Do you have integrated graphics? if you do, you should try using that instead. You'll see if it really is your card or not. Also try with another gpu (if you have one). if its the card that's really defective i think its an rma case...
R5 3600x | RTX 3070 | 16Gb 3200mhz | Gigabyte B550 gaming x | 500gb 660p SSD + 1tb wd blue HDD |
https://linustechtips.com/topic/504596-gtx-950-issues/#findComment-6735634
Make sure your GPU is pushed in all the way. Don't be afraid to use force. When I was experimenting with my PC something very similar to this happened.
Build: i5-4460 | GT 720 | Logitech G710+ Keyboard | Corsair M65 Mouse | Dell e2314h Monitor | Windows 10
Generic Dell: Mobo, 8gb RAM, 430w PSU, 1TB Storage, XPS 8700 Case
https://linustechtips.com/topic/504596-gtx-950-issues/#findComment-6735641
