I would recommend Plantronic Gamecom 380, thes ones which I use.
You would be hard pressed to get a better "headset" without spending a fortune on gimmicks like surround sound (in headsets)
Could also go for steelseries siberia v2.
It also depends on what features you want, 7.1? wireless? closed/open ear cups? leather/cloth ear pads? etc
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/50382-headset-help/#findComment-672132
What you need to realize is that those headsets are "gamer" headsets.
They are usually just normal cheap headsets with gimmicks attached to them and the price drove up because they are "gamer" ones.
Both the ones you are looking at have 50mm drivers though, they should sound similar and are pretty much as cheap as you are going to get for the driver size.  Although that doesn't necessarily mean they will be "better" than cheap headsets with 40mm drivers as everyones hearing is different, you might not be able to tell the difference.
https://linustechtips.com/topic/50382-headset-help/#findComment-673444
