I want to connect my 4th monitor as an extended view. I have 3 in the middle as surround. Is it possible to connect the 4th one using integrated graphics? I really do not feel like installing a 2nd gpu for that monitor.
Wishing leads to ambition and ambition leads to motivation and motivation leads to me building an illegal rocket ship in my backyard.
https://linustechtips.com/topic/503790-setting-up-4th-display/
I think plugging it in your mobo solves that.
"In the middle of every difficulty lies opportunity."
- Albert Einstein
https://linustechtips.com/topic/503790-setting-up-4th-display/#findComment-6725858
It's not being detected. I plugged into the mobo.
Your Answer is Here: http://linustechtips.com/main/topic/173908-using-integrated-graphics-to-power-second-monitor/
- Albert Einstein
https://linustechtips.com/topic/503790-setting-up-4th-display/#findComment-6725874
You might have to enable it in the bios
I do it.
So this would work even If i have surround on the other 3?
https://linustechtips.com/topic/503790-setting-up-4th-display/#findComment-6725899
