Power trip when overclocking?
Solved by i_build_nanosuits,
Well why though? I've thought of that as a solution but I'm a bit paranoid "might cause a fire" or some other stupid shit hahah
Your computer need the PSU power even when not running to hold BIOS settings in and stuff...otherwise you'll drain the battery on your motherboard or it will damage the battery in the long run.
Only fully drain power from the machine when you plan to unplug from the wall and do maintenance or other work on the machine.
What you are doing is not good.
