help
Go to solution Solved by GodSpoon,
but i have had this for about 4 years
http://www.macworld.co.uk/news/mac/widespread-2011-macbook-pro-failures-petition-lawsuit-repair-programme-3497935/
Doesn't matter, its a recall because of the shotty boards they put into them
Trust me, take it in, they should fix it for free
My laptop is a macbook pro 13 inch 2011 model with 8gigs of ram added to it so instead of 4 i have 8 gigs which bumps the virtual memory to 512MB
Its been restarting a lot randomly recently and i have gotten the apple version of a BSOD so many times its hard to count (like 20 in the past month)
My laptop restarted just now and i am fed up of dealing with this shit,
anyone have any suggestions on what the problem might be?
OFF TOPIC: I suggest every poll from now on to have "**CK EA" option instead of "Other"
https://linustechtips.com/topic/502846-help/
My friend brandon had the same problem, same year laptop
Motherboard failures are a known defect for it, take it to an apple certified shop near you and tell them what its doing
They'll run tests for it and if thats what it is, since its a recall, they'll replace the mobo for free
https://linustechtips.com/topic/502846-help/#findComment-6714044
https://linustechtips.com/topic/502846-help/#findComment-6714052
https://linustechtips.com/topic/502846-help/#findComment-6714064
