Boot up screen help
Go to solution Solved by Imakuni,
Hi I was wondering if the boot up screen on my PC is able to be taken of the screen is a msi one with the command at the bottom press F11 to open bios
Usually there's a setting "display logo" or something weird like that. Just go browsing everything in your bios, you should find it... somewhere.
And if your mobo supports it, you can also patch a custom image for display.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/502806-boot-up-screen-help/#findComment-6713795
how would I know if my mobo supported it I have a msi z170a m5
https://linustechtips.com/topic/502806-boot-up-screen-help/#findComment-6714667
As far as "official" support, I think Gigabyte is the only one that provides an app to customize your mobo's logo. It can also be done through 3rd party options......
.... HOWEVER, that's Bios Modding and I won't guide you into it, as I don't recommend it.
https://linustechtips.com/topic/502806-boot-up-screen-help/#findComment-6715224
