HP G72 power issue
By
checkmate
in Troubleshooting
in Troubleshooting
Solved by dragoon20005,
I checked the charger port, it seems fine. None of the connections are loose or anything. I also looked at this before I came here. I'm assuming its the motherboard?
Edit: Also checked, im using a 90W power cable thing, it should be fine right?
yes it fine so i guess it needs a new mobo
denizayciceks ·
Posted in Troubleshooting9 -
5
Macaw ·
Posted in Console Gaming5 -
4
2
Shahrad ·
Posted in LTT Releases10 -
9
