Did you try resetting the computer?
My Work in Progress PC http://linustechtips.com/main/topic/522048-xeon-build/ <-- That PC was built but never booted:(
My Work in Progress PC 2.0 https://linustechtips.com/main/topic/540583-xeon-build-20-code-name-xenox (Hopefully this one boots.)
https://linustechtips.com/topic/502427-audio-problem/#findComment-6708099
lol welcome to windows 10. I've been fighting bugs literately everyday since i installed it. i encountered many bugs from programs uninstalling themselves, afterburner not saving and applying my overclocks on startup, settings changing themselves, not being able to create a M$ account because the window would pop up and close, not being able to make a new user account for the same problem. and many more. I've done 2 fresh installs in less than a week do to bugs.
are you sure the audio jacks are plugged into the right ports on your mobo? sorry. hav to ask. There are alot of unique people out there
Tsubasa (The 7680x1440 beast): CPU: Intel i7 8086k | Cooler: Fully Custom Rigid Loop MOBO: Asus Z370-I ITX | GPU: Nvidia Titan Xp Star Wars | RAM: 32Gb 2x16gb Gskill Trident Z RGB | SSD: Samsung 1TB 970 Evo Nvme, 2TB Micron Sata SSD | Case: Fractal Design Nano S | PSU: Corsair SF600 With Full custom cables
https://linustechtips.com/topic/502427-audio-problem/#findComment-6708123
Yes, it is. I tried doing this as well. https://www.reddit.com/r/GlobalOffensive/comments/2e6xsr/potential_fix_for_those_experiencing_fps_lag_and/
https://linustechtips.com/topic/502427-audio-problem/#findComment-6708254
