simple monitor
luke8733
Hello, I am looking for a monitor with 1-2 HDMI ports for my Macbook Pro and Xbox. I am simply looking for a 1080p 60Hz IPS panel with a refresh rate of about 1-3ms. I would also like the monitor(s) to have good reviews. Budget is about $150. Thanks in advance.
You won't find an IPS panel with a response time lower than 4ms.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
Here is an ASUS IPS monitor with two HDMI ports: http://www.newegg.com/Product/Product.aspx?Item=N82E16824236557
Also please ignore response time numbers, they are completely meaningless.
 Well that's not true at all, but people do place way too much value on them.
"Epic Voice, Quality Content"
No, they literally are meaningless. It tells you absolutely nothing about how much ghosting the monitor will have. See the link in my description for more details.
Most people who worry about response time aren't looking at those numbers for ghosting measurements anyway.
They're looking for BS they're fed about input lag. Which again - don't have the impact people think they do - but still say something.
Response time has nothing to do with input lag :P
