What is a good 7970 card for overclocking, looking at the gigabyte one but it has locked voltage :(
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/50211-best-7970-overclock-card/
MSI 7970 Lightning. :P
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/50211-best-7970-overclock-card/#findComment-669429
Asus 7970 Matrix. Pair it up with an Extreme board and you can VGA Hotwire it to Over volt.
Oh yeah! i forgot all about the Matrix!
https://linustechtips.com/topic/50211-best-7970-overclock-card/#findComment-669436
ok i would go gtx 770 if I could get that card
https://linustechtips.com/topic/50211-best-7970-overclock-card/#findComment-669437
Keep it at 400 please!!!
https://linustechtips.com/topic/50211-best-7970-overclock-card/#findComment-669440
https://linustechtips.com/topic/50211-best-7970-overclock-card/#findComment-669450
Yeah, thats really good. I still prefer the 770 Lightning over the ACX.
https://linustechtips.com/topic/50211-best-7970-overclock-card/#findComment-669461
You went from a 7970 to 770? Stretch your budget by $50 and you'll get a 7970 Matrix Platinum :P VGA Hotwire is actually supported on all current RoG boards.
how do you go form 400 to 450
https://linustechtips.com/topic/50211-best-7970-overclock-card/#findComment-669484
MSI 7970 Twin Frozr III/IV / HIS IceQ X2 7970 / Sapphire Dual-X 7970
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/50211-best-7970-overclock-card/#findComment-669530
the matrix platinum is the best OC card. This is not an opinion but a fact. Easily the greatest from AMD to date
Due everything you can to afford this
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/50211-best-7970-overclock-card/#findComment-669621
Maybe on LN2, because of their custom PCB. But on air or water they pretty much suck. I haven't seen a 7970 Matrix on air or water put out any overclocks over 1300Mhz one the core, yet a lot of reference cards can do it on water. If they used binned chips then I could see the the advantage, but they don't. I would suggest taking a look at the OC.net forums and see how many happy Matrix users there are.... One guy even broke his in half is sucked so badly :) Don't buy into the matrix hype.
5820K - ASUS X99-A - 16GB Corsair LPX - HD 7970 GHz - Qnix 1440p @ 96Hz - Waiting for Polaris/Pascal
https://linustechtips.com/topic/50211-best-7970-overclock-card/#findComment-672331
i went with a Sapphire 7970. it was 309USD before 20USD rebate. clocked it to 1150/1525 without increasing voltage. runs cool and quiet. also it is voltage unlocked, make sure of this no matter which card you choose.
CPU: FX-8350 Cooler: NZXT Kraken X60 w/2X NF-A14 FLX MoBo: Asus M5A99FX Pro Rev 2.0 Memory: 8GB G.Skill Sniper@1720 GPU: Sapphire Dual-X HD7970@1100/1500 Storage: Samsung 840 120GB(OS), Seagate Barracuda 1TB 7200 64MB PSU: Sparkle 850W Gold Case: Corsair C70 Military green w/ Solid window Keyboard: Ducky Shines 3 (MX Blues), Razer BlackWidow 2013 Ultimate Mouse: Corsair M90,M65 w/ Vengeance MM600
https://linustechtips.com/topic/50211-best-7970-overclock-card/#findComment-672461
Get a 2nd hand proven beast overclock reference 7970 and watercool it. It's all about silicon lottery. Some guy mentioned Matrix, no... just no.
https://linustechtips.com/topic/50211-best-7970-overclock-card/#findComment-672862
Maybe because this is a $475 card that is no better than a $350 card....
price aside 1.3ghz is a very high and impressive oc.I read that the matrix has a very noisy cooler so that alone turns me off and the price defiantly is to high i agree.
AMD Phenom II x4 955 OCed, HD 7850, LG 27EA33 1080P IPS, 4GB ram
https://linustechtips.com/topic/50211-best-7970-overclock-card/#findComment-673221
