Hi guys!
I have an older Samsung 40" tv. 2012-13 maybe?
Just bought Sony BDV-E4100 the surround set.
http://www.sony.co.uk/electronics/all-in-one-home-cinema-systems/bdv-e4100
It's all new, so nothing is broken or has defect.
The same set worked perfectly with my mothers newer (2014) Phillips TV.
Just hooked it up through HDMI, and it installed itself onto the TV.
Every time i would watch TV, it would activate itself.
On this older samsung TV it tried to do the same,
it says TV-mode on the display, but no sound is coming out.
Seems like there is no proper connection.
Would adding an Optical audio cable work? ( they both support it).
The phillips tv worked without one. Just through HDMI.
AMD Ryzen R9 5900X  | Arctic Liquid Freezer II 360  |  GIGABYTE X570S AERO G  |  2x32GB G'skill TridentZ 4000MHz  | MSI RX 6900 XT Gaming Z Trio 16GB Dark Base Pro 900 (Orange)  | TOSHIBA 4TB 3.5" Drive - Game Drive | KINGSTON SNVS1000G 1TB M.2 NVME SSD - Boot Drive | FSP Hydro PTM PRO 1000W |
Living Room PC: AMD Ryzen 2400G | MSI RX VEGA 56 8GB AERO | 2x8 GB Crucial Ballistix 2400MHz | Intenso 250GB SSD | Seagate 500 GB HDD | Node 202 + 850W PSU |
https://linustechtips.com/topic/501656-will-optical-audio-cable-help-here/
