Hi I was wondering if anyone could help me get my Ethernet set up. I have a dLAN 500 AV Wireless+ but I can't get it working with my pc! My PC says connection limited and I can't access the internet when I have it set to Ethernet on my PC and when it's using the wifi extender to. pls help! It also says unidentified network on the Ethernet.
post-193049-0-95391300-1449607844_thumb.
https://linustechtips.com/topic/501636-trouble-with-dlan-adapter/
2 one goes to the router the other to the pc. I did a windows diagnostic and it said it doesn't have a valid IP configuration!
It looks like the two adapters are not connecting to each other properly. Look at the instructions and figure out how to pair the adapters. There should be a button you press on both adapters.
i7 4790k | GTX 970 | 16GB
That's all you need to know. It's a beast.
I have done that and Im pretty sure they're connected
Why are you linking me to my own post?
Because I posted the wrong clipboard and the coudflare blocked me.Thus I could not edit
Could you run ipconfig/all in cmd and post the result here?
Funny if you write cmd. exe you are getting blocked
https://gyazo.com/84f61964e88b2bea7adb894b7aa2364c
