is the Philips 32" LED TV 32PFT4100/12 suitable for gaming?
I see your point. I'm not gonna give two shits anout lag after seeing my reaction time. thanks
Not quite relevant as your eyes interpret data much faster than a muscle can respond, though he has a point, unless you are a competitive gamer it doenst matter that much
Then again if you read TFT Central you will see that anything over 16ms of lag (input lag + signal processing = total lag) means that on a 60fps videogame you are losing 1-2 frames every second
so you want sub 16ms total - and you can see from their reviews that monitors with say 4.2ms of input lag, might have 8.4ms total lag time - so the numbers are hard to look at in that way
Anyway
As I say, from a normal monitor distance
1080p = 19-24" max
1440p = 27-30"
4k = 30"+
and then just get the best monitor you can afford, low input lag, IPS, 144hz, Gsync - whatever features you want and can afford
Hope that helps
