Motherboard Upgrade Help
Go to solution Solved by Guest SkyFall,
In a couple of weeks I plan to upgrade my motherboard from an ASrock Z97M Pro4 mATX to a MSI Z97 Gaming 5. Everything else that is inside of my system I will be keeping the same. When switching motherboards what precautions should I take, and will I have to reinstall windows 10 onto it?
Any help will be great.
Specs:
CPU: i5-4690K @ 4.4 Ghz
GPU: R9 390
PSU: EVGA G2 750W
RAM: Corsair Vengeance 8 Gigs
SSD: HyperX Fury 120 Gb with Windows 10 installed onto it
HDD: WD Blue 1 TB with games and other applications
First post
Make a backup of all your data, just in case you damage something while changing the mainboard.
Specs:
GPU: R9 390
PSU: EVGA G2 750W
First post
https://linustechtips.com/topic/501287-motherboard-upgrade-help/
You will have to call Microsoft to give you a new product key since keys are tied to a motherboard.
Is there a reason you are upgrading other than aesthetics?
The main reason is for aesthetics and also for the ASrock motherboard is going to be put into a different build for just office use.
https://linustechtips.com/topic/501287-motherboard-upgrade-help/#findComment-6693026
Specs:
GPU: R9 390
PSU: EVGA G2 750W
First post
https://linustechtips.com/topic/501287-motherboard-upgrade-help/#findComment-6693511
