Advice for choosing a case based off GPU
Go to solution Solved by Senzelian,
Like Shadowbyte already said - the Fractal Design Define S is absolutly amazing and has everything you need.
Great airflow with up to three 120mm fans in the front, it's very simplistic, looks great and easy to build in and you get a high quality case for a really low price.
Hi, I'm currently wanting to upgrade my case. I am buying two sapphire 390's and they are pretty long (12 inches)
Other  specs: BOARD: asus p8z77-v lk
Power supply: Antec HCG 900w
So I really have no idea on what case to get... I'd like to get a case that is big enough, has good airflow and cooling, and has a good price (hoping not to spend more than 130) I don't need anything crazy and fancy and It would be awesome to get something around $100 or less if possible. Any advice would be VERY helpful. :)
https://linustechtips.com/topic/501093-advice-for-choosing-a-case-based-off-gpu/
S340
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
Define S
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
