Hello can you check my pc build?http://pcpartpicker.com/p/hw6nxr i dont know if i shoud choose another motherboard like Asus Maximus VIII Ranger Intel Z170 SK1151 or Gigabyte Z170X Gaming 5 Intel Z170 SK1151 I also would like to know which video card i should choose for my build. Feel free to tell me how to make it better. thanks:)
https://linustechtips.com/topic/500963-help-chosing-components/
What is ur budget for the video card?
https://linustechtips.com/topic/500963-help-chosing-components/#findComment-6689021
I love any of the corsair towers, The 100r is really cheap, classy and has a pretty big window, I was planning on getting it for my next rig. But maybe you'd like something less serious and minimalist, like the SPEC series. It all depends in how much are you willing to pay and you personal preferences.
thanks!ill loo into it
https://linustechtips.com/topic/500963-help-chosing-components/#findComment-6690410
