drive not accesable?
Go to solution Solved by Samppa221,
Get into disk management and right click on the unallocated and new simple volume and next next..
theres a 64gb m.2 ssd installed shows on my pc device manager a seen in picture. but it doesnt show as accesable drive in windows itself and also not under the drive manager what means i cant assign a letter to it. how do i get in the ssd?
http://m.imgur.com/7lbR771
https://linustechtips.com/topic/500187-drive-not-accesable/
You have to format it before you can use it.
|| CPU - i7 4790K @4.6GHz || GPU - MSI GTX 980 Gaming 4G || Motherboard - Asus Z97-A || RAM - 16GB Kingston HyperX Fury @1866MHz |Case Be quiet! Silent Base 800 ||
|| CPU Cooler - Cooler Master Hyper 212 EVO || Storage - Samsung 850 Pro 256GB & Seagate Barracuda 2TB (+ WD Caviar Green 2TB) ||
|| Mouse - Logitech G502 Proteus Core || Keyboard - Corsair K70 (MX Red) ||
https://linustechtips.com/topic/500187-drive-not-accesable/#findComment-6679663
https://linustechtips.com/topic/500187-drive-not-accesable/#findComment-6679713
