So a few weeks ago i cleaned my Razer Blackwidow ultimate and i accidentally removed my shift key and the holder thing marked with red (only the right holder not the left) http://imgur.com/zGfuZJr
popped out and i put it back on after a few minutes of figuring out how to put it back on.
So now i noticed that the right side of my shift key is very heavy while the left side still remains smooth and clean, is it because of the oil or something else?
Do i have to re-oil it? And if so, with what?
PS: Ignore the right holder with the red around it.
https://linustechtips.com/topic/500117-heavy-shift-key/
Is the right switch heavier than the left one? or is it heavier on the right when you put the keycap back on?
My Rig:
Model: P650RG | Brand: Clevo | CPU: 6700HQ | GPU: 980M | RAM: 16GB KINGSTON HYPER-X DDR4 | SSD: 2x 480GB Kingston KC300 | Screen: 3K Panasonic IPS LED
https://linustechtips.com/topic/500117-heavy-shift-key/#findComment-6678932
