Switch the two ram in the different slots, if that doesn't work just insert the Samsung ram only and if that doesn't work than clearly the Samsung ram doesn't work or is not for the laptop.
Soldered.
Ram.
Bud.
Soldered.
Check whether you're running 32-bit or 64-bit windows.
Also, check the supported ram for your laptop.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/499186-laptop-ram-problem-help/#findComment-6669546
Soldered.
Ram.
Bud.
Soldered.
Whoops didn't see that, yeah just check the version of Windows then.
"Simple Yet Complex"
https://linustechtips.com/topic/499186-laptop-ram-problem-help/#findComment-6669565
