How durable are brushed aluminium finishes on cases? I really like the look of them but I'm worried about fingerprints being stuck on it by accidentally touching it or something like that. I'm looking at the FT03 Mini in particular. For those of you with brushed aluminium cases would you care to share you experiences with it?
https://linustechtips.com/topic/49901-brushed-aluminium-case-durability-question/
I had one. after 6 months I couldn't stand it after seeing my finger prints on the edges of the case.
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
Has anyone tried power washing brushed aluminum to see if it cleans it...?
| i5-4670k @ 4.2Ghz | Corsair H100i | Gigabyte Z87X-UD4H | Corsair Vengeance Pro 8GB | ASUS Geforce GTX 770 |
| Samsung 840 Pro 128GB | WD Black 1TB | Corsair AX760 | Fractal Design Define R4 Black w/ Window | Corsair AF140 x2 |
| Windows 8.1 | ASUS 23" 1080p monitor | CM Storm Quickfire Stealth- MX Blue | Logitech G9x | Logitech G930 |
In the case of the define r4 with the brushed aluminium front it's fine for me. It has like one fingerprint on it and i can rub them off pretty easily. I don't see why you would need to ever touch the front of the case since there is nothing on it and the handle to open the front is on the side. So basically if it's only the front I find it to be 100% fine.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
The define R4 uses a fake brushed aluminium finish, I think its actually plastic.
Define R4 is actually plastic. IMO I think it's a better option than actual brushed aluminum.
That's good to know, I put hockey tape on the part where you open it so my fingers have something else to touch. I was wondering why I could clean it so easily, I couldn't even tell it was plastic.
My experience with brushed aluminum has been bad. It looks so good for a week, but then general use ruins it with oil and who knows what else that floats around. My external hard drive has an aluminum finish, and I only pick it up with a rag now.
My previous 4P Folding & current Personal Rig
I once was a poor man, but then I found a crown.
lol fooled me.
grab your white cotton gloves for that case.. the anodizing and plus the porous ally
makes it double trouble for the finger-prints. building one is the PITA, but once done
shouldn't have to touch it again except RMA or upgrades.
airdeano
