Upgrading my system
Solved by tbroadwater2010,
Max i would say about 400-500 dollars depending on the difference in performance (for example if its worth the extra hundred for a big performance boost over something i could get for 400 ill go for it)
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor ($209.99 @ SuperBiiz)
Motherboard: Asus H170-PRO ATX LGA1151 Motherboard ($110.00 @ B&H)
Total: $319.99
Generated by PCPartPicker 2015-12-04 15:17 EST-0500
This should do you plenty of good. 4 good cores and will run new systems. It is NOT a K series processor and cannot be overclocked.
