Virtualized Machine Build Specification Help
Yes, I know that SolidWorks may not be the "best" choice for this type of environment, but I'm still not officially set on what I'll use for 3D modeling and physics calculations. I chose the R9 390 because I will most often be gaming, and will be sufficient for doing things like CAD when I need to. I still don't see why it's a bad idea, because Linus's experiment didn't show much of a performance hit at all (relative to what your eyes can see at around 100 fps), and wouldn't what I'm trying to do just divide the physical hardware resources between each setup?
In the end, I'm leaning towards this concept because I have a limited budget, and replacing another computer in the house might help me gain additional financial resources to pay for the build.
Are you modeling for engineering or for animations?
For 3D CAE and this environment, i would recommend Siemens NX (~25K USD for base use package) or Dassault CATIA (~50k USD for base use package). From my experience, solidworks (particularly the drawing package) has some trouble dealing with virtualization...that being said, im sure you can tinker with it and get it to function somewhat ok but my company tried all sorts of nonsense to make it work right.
If you are mostly gaming and general use then its all good and i wish you luck.
