So I am going to be doing a dual cpu build, and I need some sort of test bench that will fit an eATX motherboard. Does anyone know of one?
Help is greatly appreciated.
Build: CPU: i7-4790k @4.4 GHz 1.2v | GPU: Sapphire R9 380 Nitro | Memory: 16GB Evga SSC | Storage: 250GB 850 Evo, 1 TB Toshiba HDD | Mobo: Gigabyte GA-Z97X-Gaming 7  | Cooling: Aigo T120 RGB | Case: NZXT S340 | PSU: Antec HCG 520w | OS: Windows 10 | Keyboard: Corsair K70, Cherry MX Reds | Mouse: Logitech G600 | Monitor: LG 27UD58-B | Headset: Audio-Technica M40x w/ Modmic and Bravo Audio V2 Tube Amplifier
https://linustechtips.com/topic/497768-need-help-for-finding-a-test-bench/
It supports E-ATX and XL-ATX
thats the most you'll get from a test bench
Lol wow didn't look like it from the pics, thanks for the help :)
Do you really need a dual CPU build?
the HAF XB EVO can technically fit one, but it's not made for it
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119265&ignorebbr=1&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Cases+%28Computer+Cases+-+ATX+Form%29-_-N82E16811119265&gclid=CMH_i5epvskCFQooaQod4uYJGw&gclsrc=aw.ds
It's really cost effective, and its fun to do something new.
New stuff can also end up being a waste of money lol, especially given your current build, how much were you going to spend on this? and were you following linus's video suggestions about old xeon stuff?
I was going to spend about 50 bucks on 2 processors, and 40 bucks on a motherboard, and 20 bucks on 16 gb of ram. Yes, I have seen Linus' video.
Here is what i recommend:
http://www.caselabs-store.com/hptx-motherboard-trays/
However, if you are handy, you can build one for almost nothing.
If you were going for cheap you might as well just mount it to a block of wood, although really I'd maybe just save and get a whole new PC
I decided, due to mainly the potential of compatibility issues to just get a 4790k and a z97. I would get a 4690k but its out of stock at my local microcenter and the 4790k is really cheap anyways
