Technically, it could screw up the case airflow...
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
Hi!
I decided to remove my side panel and "replace / close it" with curtain mesh.
Is it good idea / bad move?
Thanks :D
*Curtain Mesh : https://www.ecurtains.com/images/products/main/fine_sheer_mesh_curtain_panel_2.jpg
It depends how you have your airflow setup it can either make cooling better or worst since it can ruin the way cooling works in the case.
Hi!
Thanks
Probably a bad idea, since it will most likely screw up the main aspect of cooling which is convection  (ie heat rises and automatically sucks in cold air from below - a bit like how weather works)
Also curtain mesh? that will be ugly, you could at least go and buy some nice steel mesh haha (but still dont do it)
you guys really over estimate how much convection actually takes place in a computer case.
it depends on the case. I would on my Hadron air if I had heating problems. but keep in mind while your GPU and CPU may run at lower temps, your motherboard might not be getting as much cooling
Silverstone FT-05: 8 Broadwell Xeon (6900k soon), Asus X99 A, Asus GTX 1070, 1tb Samsung 850 pro, NH-D15
Resist!
Not really, compare the temps on an open test bench vs a case with proper air flow
its better if all the air goes in one direction, cold in from bottom, front, and exhaust out the top or back
that would have more to do with airflow, rather than convection. a case would need be much larger for convection to truly have an impact. while it is nice to have a bottom to top or front to back airflow, as components (such as the gpu) will be intaking air from the bottom, having a top to bottom or back to front, etc airflow is not going to yield any noticeable results - at least in my experience with odd cases such as the Prodigy M.
Resist!
Sure airflow is extremely important and thats why solid case sides generally improve air flow and mesh sides would ruin the airflow, but convection still does play a part
still I suppose i was more talking about having directed air flow which can make big differences
It definately does have noticeable effects but obviously depends on the configuration
