Which CPU cooler is better?
Go to solution Solved by Ostwind,
Those are all gonna perform about the same. I would suggest the Xilence one as the plastic push pins on the Cooler Master one can get messed up really easily and render the cooler un-mountable without replacement mounting hardware.
https://linustechtips.com/topic/497079-which-cpu-cooler-is-better/
"The of and to a in is I that it for you was with on as have but be they"
I recommend the Cooler Master cooler, however Ostwind does make a solid point about the mounting pins. But tbh I've never heard of that cooler doing that til now. Either way, whichever you choose will give you the same performance by the end of the day...
"What're you supposed to be? A clown or something?"
"...Sometimes."
