Hello!
I recently got my new i7 4790k for my build. I am using a Z87-A, which isnt compatible with that CPU, unless I update my BIOS.
Thats where it gets tricky. To get the support for that CPU I have to update it with their updater, and for that I need Intel Management Engine. I have installed it countless times now, but I still get the same screen when I try to update my BIOS, which is this one:
What am I doing wrong?
Very thankful for answers!
https://linustechtips.com/topic/496888-z87-a-bios-problems/
You can update it in the EZ 2 Flash tool Utility on BIOS itself. Why do you perform it on Windows?
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/496888-z87-a-bios-problems/#findComment-6643746
The best thing to do would be to upgrade the BIOS via a USB. Do you have access to another working computer to download the BIOS file?
I have already done that. And apperantly it doesnt work. It has updated the BIOS, but not to fully support that CPU. So the PC wont boot with that CPU at this point.
https://linustechtips.com/topic/496888-z87-a-bios-problems/#findComment-6643775
Which CPU that you're using to update the BIOS right now?
https://linustechtips.com/topic/496888-z87-a-bios-problems/#findComment-6643797
I am using an i5 4670k
Use that CPU to update the BIOS in the BIOS menu itself. Then put the 4790k.
You don't have to be on Windows to update the BIOS.
https://linustechtips.com/topic/496888-z87-a-bios-problems/#findComment-6643820
As I said. I have already done that. The BIOS is updated to the version that supports the i7. But I read somewhere that to actually support the CPU on this motherboard you HAVE to update it through the windows updater.
https://linustechtips.com/topic/496888-z87-a-bios-problems/#findComment-6643835
Nope.
Just place the 4790k on motherboard.
It'll work for sure.
It has nothing to do with Windows Update.
https://linustechtips.com/topic/496888-z87-a-bios-problems/#findComment-6644050
Nope.
Im not talking about windows update. Asus have their own special method of updating BIOS. It uses an installer that your run through windows.
I have updated BIOS with EZ flash to the right version, but it did not work unfortunately :/
EDIT: As seen here, you can not update the Z87-A with flashback to get support for new CPUs.
https://linustechtips.com/topic/496888-z87-a-bios-problems/#findComment-6644154
What do you mean by it didn't work?
Did you follow the procedures?
https://linustechtips.com/topic/496888-z87-a-bios-problems/#findComment-6644233
Yes. Ive updated the BIOS with a USB through EZ flash utility inside the BIOS. It has now been updated from version ???? to version 2004 (The version they say should support this CPU).
https://linustechtips.com/topic/496888-z87-a-bios-problems/#findComment-6644290
The latest one is
Description Z87-A BIOS 2103 and BIOS updater
Improve system stability.
File Size 12.37 MBytesupdate 2014/09/12 Download from Global
Try this!
https://linustechtips.com/topic/496888-z87-a-bios-problems/#findComment-6644369
Flash back means as it sounds.
You're flashing your bios backwards, not forwards. So your motherboard does not support you flashing your bios to a previous version. (you can do it with a floppy drive, but can be difficult).
It's not a race to the bottom.
https://linustechtips.com/topic/496888-z87-a-bios-problems/#findComment-6644605
Im pretty sure it doesnt mean that, since I am updating it to a later version.
I know its an Asus technology that lets you update your BIOS without installing any components.
But as I am saying, I dont care at all about updating my BIOS with a usb stick, since it is clearly not working.
I am looking for a solution to install ME correctly so I can update my BIOS the other way.
https://linustechtips.com/topic/496888-z87-a-bios-problems/#findComment-6644872
Download this on your mobo support site.
https://linustechtips.com/topic/496888-z87-a-bios-problems/#findComment-6645026
