After using my computer for 30-35 min it will get really slow. Slow to the fact that i cant use it and need to restart. Everything registers but something like a mouse movement will happen 10 seconds after i do it. And when i try to open task manager to see if something is wrong with ram/cpu/disk it opens 10 min later and says "not responding" and doesn't show me anything. I have a 4790k and a GTX 970 with 8 gigs of ram and windows 10 64 bit. I had a similar problem before but it wasnt as severe and i thought i resolved it a while ago.
Thanks
https://linustechtips.com/topic/495390-computer-lags-after-using-it/
might be a virus or a drive dying
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
run a virus scan.
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
