SORRY FOR LONG POST: had to be really detailed
So I just built my new PC. i7 4790k w/ stock cooler (upgrading soon), GTX 780 (had it since July it was a gift from a friend) 16GB of RAM, Corsair RM 750 and an MSI Z97 SLI Krait edition. So lately I started playing insurgency like a lot. I noticed my frame rate dips below 60 a little more often than I'd like not for longer than 5 seconds though. It also seems to be a bit more CPU intensive than my other games (speculation) My CPU load is like 15% normally while in-game but during my last session it was around 30%. Temps are max 75 while in-game. I also noticed that in GTA V the last few times I've run it the game likes to drop to 30FPS for a while. It'll go back up and fluctuate but for the first like 40 hours I had a solid 60 with very very minimal dips and not for any longer than 10 - 20 seconds. So is this my CPU throttling? Should I do any sort of maintenance?
System: i7 4790K, Hyper 212 EVO, 16 GB Crucial Ballistix, GTX 1070 Super clocked, MSI Z97S SLI Krait Edition, Corsair RM 750, Corsair 750D (with 2 additional 140mm NZXT fans up top for exhaust.)
https://linustechtips.com/topic/494975-hardware-maintenance/
you cant really do any maintenance just get a better cooler also what monitor do you use because if you playing max settings on higher than 1080p your frame rates going to drop below 60
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/494975-hardware-maintenance/#findComment-6623893
It may be throttling. But you are doing the right thing by getting an aftermarket cooler.
https://linustechtips.com/topic/494975-hardware-maintenance/#findComment-6623894
See I would've told any other person that you can't but idk I just felt like maybe, just maybe. Instead I come here and act as though I haven't been doing this for 3 years.
https://linustechtips.com/topic/494975-hardware-maintenance/#findComment-6623903
Yeah, I would've when I bought it but I couldn't really afford to spend the extra cash and I wanted to do some research I'm sure I'll get the Noctua U12S though
https://linustechtips.com/topic/494975-hardware-maintenance/#findComment-6623912
Get the demo version of AIDA64 (Linus has a full license and uses that for benchmarks; the demo version simply has a bit of limited functionality and has a watermark over the graphs, but still is excellent). Run a stress test and check for thermal throttling detected. If you want to go one step further, get CPUID CPU-Z and watch the clock speed on the main page. Run a stress test. If you see a dramatic clock speed drop mid-stress-test, that means that your CPU's probably throttling. If you have any kind of overclock, it's throttling. End of story. It spits out a TDP of more than 135W.
"Not breaking it or making it worse is key."
"Bad choices make good stories."
https://linustechtips.com/topic/494975-hardware-maintenance/#findComment-6624019
I usually have real temp and task manager open while gaming, but I'll give that benchmark a shot, should I 100% load with the stock cooler?
https://linustechtips.com/topic/494975-hardware-maintenance/#findComment-6624405
It will show you if you're getting any thermal throttling. Try to push the system. See how much it thermal throttles in AIDA64. It will show you in the bottom graph as a red line. Once that even starts to jump to 10% throttling detected, end the stress test. That's how you know. If you want to see how bad the problem really is, you can run the test for longer with negligible long term damage. Something like a tall Noctua air cooler (get some NF-F12s while you're looking as aux cooling), or a Corsair H100i (again, ditch the stock fans on that AIO liquid cooler and stick Noctua NF-F12s to it) will be fine for any overclock. BTW, the Noctua NF-F12 is both Linus AND Luke's favorite fan. It's a very silent, very well built pressure optimized fan. And if you want to be awesome, then you can get the custom LinusTechTips branded and colored fans (rather than puke brown and vomit tan). Or you can get an Industrial PPC also from Noctua. I'm a fan of Noctua's fans.
https://linustechtips.com/topic/494975-hardware-maintenance/#findComment-6624487
Could I pull a stable 4.7 GHZ OC on air? I want a considerable bump for when I'm editing and doing work in after effects.
https://linustechtips.com/topic/494975-hardware-maintenance/#findComment-6624578
Short story: Maybe. Silicon Lottery. It depends.
Long story: Maybe. Silicon Lottery. It depends. You'll have to explore. A decent cooler like the Noctua cooler or the Corsair cooler mentioned above is plenty capable. I personally prefer to use a custom loop because I also use my PC as a capture PC through SDI and also for animation and video editing work, but some people may not be comfortable with this. Just make sure that the rated TDP of the cooler is greater than 140ish. More is better, but also more expensive. Air is much more powerful than you think it is, and good air coolers like:
-be quiet! Dark Rock 2 or Dark Rock
-Noctua NH-D15 or NH-D15S or NH-D14
-Corsair H100i or H100i GTX or H110 GT or H80i GT
Again, swap out those fans with Noctua NF-F12s, especially on the Corsair liquid coolers.
https://linustechtips.com/topic/494975-hardware-maintenance/#findComment-6624596
Silicon Lottery. It depends. You'll have to explore. A decent cooler like the Noctua cooler or the Corsair cooler mentioned above is plenty capable. I personally prefer to use a custom loop because I also use my PC as a capture PC through SDI and also for animation and video editing work, but some people may not be comfortable with this. Just make sure that the rated TDP of the cooler is greater than 150ish. More is better, but also more expensive.
I've been considering water but I just have some hangups about it and I know corsair covers your parts if their cooler leaks. What is maintenance like with liquid coolers?
https://linustechtips.com/topic/494975-hardware-maintenance/#findComment-6624616
With these closed loops (meaning you can't refill or drain the loop), minimal. You don't have to worry about metal compatibility or any of that. Just make sure that the fans on the radiator are configured properly...
https://linustechtips.com/topic/494975-hardware-maintenance/#findComment-6624650
In fact, it's just as easy as an air cooler. Just some cable management with the tubes for the block and rad.
https://linustechtips.com/topic/494975-hardware-maintenance/#findComment-6624658
