Led lighting
Go to solution Solved by W-L,
Hi all!
I want to add some led lighting to my case but I can't find any led lighting strips in hungary. Is it possible to hook up a normal 12V led lighting strip to a molex connector? If it's possible is it risky to do that?
Thanks a lot!
For LED strips if they are the single color ones, yes they can be hookup up directly to a 12V source.
I have a write up here on how to do this under Wiring Up LED Strips:
http://linustechtips.com/main/topic/407754-modding-faq-common-mods/
Hi all!
Thanks a lot!
Intel core I5 4460, Gigabyte H97M-HD3, Gigabyte gtx 760, 8 GB corsair value ram, Thermaltake core v21, Thermaltake Smart 630W PSU
Alcatel OneTouch D5... IT WORKS!!
http://pcpartpicker.com/p/BxMjTW
https://linustechtips.com/topic/494004-led-lighting/
Hi all!
Thanks a lot!
https://linustechtips.com/topic/494004-led-lighting/#findComment-6616384
