Hi, I don't understand printers at all. But its black friday so I am wondering between these 2:
Samsung SL-M2070  /OR/ Canon i-SENSYS MF211
Samsung ink cartage serves 1000 pages but Canon's does 2,400. I wont be using 2 400 pages, at least not for 2 years. Isn't the ink going to dry?
CPU: Ryzen 5 2600, MOBO: MSI Tomahawk B450, RAM: Corsair Vengeance RGB 3000 (2x8 GB), GPU: MSI RTX 2080 Gaming-X Trio, CPU Cooler: Noctua NH-U12S, PSU: Corsair RM 650, HDD: WD Blue 1TB, SSD: Samsung 860 ECO 500GB, CASE: Fractal Design Meshify C
https://linustechtips.com/topic/493578-advice-for-choosing-laser-printer/
I have owned like 5 printers, all 5 broke down without even using them for a year lol.
Make sure dem reviews are good before you buy them, and the ink won't run dry, the nozzle with get dusty and scribble blanks down.
Laserjets use a powder to print so it never dries out and can sit indefinitely.  My opinion which doesn't really help your choice is that HP Laserjets are bulletproof.  I have one that's 20 years old and still works.  Another that's 6 years old and still works after printing probably a several thousand pages.
http://www.amazon.com/gp/offer-listing/B000FGLYWM/ref=sr_1_1_olp?s=electronics&ie=UTF8&qid=1448612514&sr=1-1&keywords=hp+1018&condition=used
+ a generic toner cartridge and you're off to the races.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
Thank you. But I need the 3in1 combo. Scanner/Printer/Copier
thank you thogh. If you belive LaserJets are good, then Iam wathcihg at
HP LaserJet Pro MFP M125nw
