There is always a risk of any component like this leaking.  The question is...is it worth the risk to you?  I do not hesitate to use liquid cooling or any aio coolers, because I am prepared to cut my losses if they leak.  If you can't afford to replace something that might get damaged...maybe just get a nice air cooler instead.
https://linustechtips.com/topic/492535-help-me/#findComment-6602093
