Replaceing Projector fans
Solved by GodSpoon,
Yes! They will just run at a constant speed unless you put resistors in
You could try to just run the wires inside the headers though and tape them in case you want to reuse the fans someday, but I understand size constraints
But yes more than likely they will be fine as long as the voltage is high enough to turn them
and if the other fans were loud and 7v isn't exactly that much so I think you will be fine
