So My fans are pretty good and are hooked up to a fan controller, but my question is... Is there anyway I could give them more power to make them go faster? Also should I hook my cpu fan up to the fan controller? Then the last one is where should I put the temp cable?
https://linustechtips.com/topic/491647-fans/
I did and also should I hook up the cpu fan and where do I put the temp cable
NO! :lol: Leave the CPU fan where it is, that way it adjusts the fan speed according to CPU temps. I have my temp cables ziptied to the power for the GPU, where the case is the warmest.
If anyone asks you never saw me.
https://linustechtips.com/topic/491647-fans/#findComment-6592416
