Hi, I want your opinion on the best mini-itx case and to link it down below. At the moment this is my favorite. http://www.amazon.co.uk/Phanteks-PH-ES215P_BK-Enthoo-Mini-ITX-Chassis/dp/B00U8625HC/ref=sr_1_1?ie=UTF8&qid=1448303067&sr=8-1&keywords=phanteks+enthoo+evolv+itx
CPU: Intel i7-4790k | Cooler: Corsair H110i GT | Motherboard: MSI Z97I AC  | Graphics Card: SAPPHIRE R9 280  | http://uk.pcpartpicker.com/p/pszsdC
http://adamredfern.co.uk
http://rewinded.co.uk
http://yewtreeservices.co.uk/
http://asiat.co.uk/
http://ssstelecom.co.uk
http://hndrx.co.uk/
http://wisemove4u.com/
https://linustechtips.com/topic/490831-mini-itx-case-showdown/
I kinda want to build in the Enthoo Evolv but I like the size of the SG13.
Sig under construction.
https://linustechtips.com/topic/490831-mini-itx-case-showdown/#findComment-6581193
Me too, I can't decide between the Phenteks or the SG13 for my new build of an i7-4790k, what do you think I should go for?
http://asiat.co.uk/
http://hndrx.co.uk/
https://linustechtips.com/topic/490831-mini-itx-case-showdown/#findComment-6581242
ncase m1 v5
CPU:  i7 4770k @ overclocked to 4.4ghz             GPU: Intel HD4600        SSD: Kingston V300 120GB (OS)                   Cooler:  Corsair H100i GTX
Case: Phanteks Enthoo Evolve (Black)                RAM: 2x4gb Corsair Dominator Platinium 2133mhz  HDD: 1TB Seagate                                            Mouse: Logitech G502
OS:     Windows 10                                                      PSU: Corsair RM850i 80+ Gold                                          Motherboard:  AsusZ97 Pro Gamer              Keyboard: Vortex Pok3r 3
https://linustechtips.com/topic/490831-mini-itx-case-showdown/#findComment-6581249
Silverstone FTZ01, then again you really can't do water cooling without some extremely tight fits.  I used this case for a gaming HTPC using my 2700k and gtx 680.  If you don't mind excluding water cooling then this case will fit a very good amount of hardware including full-sized gpu's
https://linustechtips.com/topic/490831-mini-itx-case-showdown/#findComment-6583419
Whats the difference between the v5 and v3?
V5 not out yet tho. Coming soon so I have no idea too.
https://linustechtips.com/topic/490831-mini-itx-case-showdown/#findComment-6583944
