Hey everyone, recently my CPU has been acting strange, when playing graphically intense games, FO4 SW:BF etc the CPU only goes up to about 60% usage which causes low frames per seconds.
The problem seems to solve itself randomly, keeps appearing and reappearing.
I have an i5 4690k and I am using an H100i to cool it, under full load it's max 70C or so, 40-50 on idle.
Google didn't seem to have any solutions, please help me, it's really annoying.   :(
https://linustechtips.com/topic/490812-low-cpu-usage-until-restart/
is the chip throttling at all?
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Throttling? Thermal Throttling or....
If you meant thermal then no, stable temps max 70C when playing.
Disable any power saving feutures and set windows power plan to High Performance
Shark Rampage V: AMD FX-4350 @ 4.5GHz(1.404 Volts) / Hyper 212 Evo / Gigabyte 750Ti (1405MHz Core,3200MHz Memory @ stock voltage) / Kington HyperX Fury 8 Gigs 1866MHz Dual channel / ASUS M5A97 R2.0 / WD Caviar Blue 1TB 7200 RPM / 850Evo 250GB / XFX TS 550w 80+ Bronze Sharkoon VG4-W
Thing is it's started about 2-3 days ago, haven't changed any settings though.
As I sai,try the above you never know.Whats your PSU?GPU?If its only CSGO,it has been having performance problems for the past couple of patches,its not only you.
No no no, i'm not having performance issues on CSGO, only on graphically intense games.
I have a 980 TI and a 620W PSU
EDIT: Also my windows settings are set to high performance, so are my Nvidia Control Panel settings.
How much RAM?
