So recently I got a flash light with rechargeable batteries and a charger and found out I can use the charger on other rechargeable batteries too.
However, I don't know where I can get some and what brands are good.
I'd like to get some AA,AAA,If I can.
So could someone recommend me some brands or link me ones you've used or liked?
https://linustechtips.com/topic/490552-rechargeable-batteries/
Eneloops are some of the best rechargeable ones out there.
http://www.amazon.com/Panasonic-Advanced-Individual-Rechargeable-Batteries/dp/B00JHKSMJU/ref=sr_1_3?ie=UTF8&qid=1448264173&sr=8-3&
https://linustechtips.com/topic/490552-rechargeable-batteries/#findComment-6578275
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/490552-rechargeable-batteries/#findComment-6578279
Been using Sanyo Eneloops for the past billion and a half years. They can get pretty expensive but they're worth it.
My current set is about 3 years old and they're still doing a fantastic job
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/490552-rechargeable-batteries/#findComment-6578283
This, and those Duracell recharge ables are just rebrands of them.
My AMD Build:
FX 6300 @ 4.8GHz, Zalman CNPS14X, MSI 970 Gaming, 16gb 1866MHz AData Ram, 3D Club R9 280X, Corsair 600M Psu, Thermaltake V3 AMD Edition Case, D-link 1200AC WiFi, 240gb Mushkin SSD, 2tb WD HDD, 140gb WD HDD (recording gameplay), 5x CoolerMaster SickleFlow 120mm fans, Windows 10 64Bit
Sisters Intel Build:
I7 4790k @ 4.4GHz, CoolerMaster 212 Evo, Gigabyte Gaming 5, 16gb 1866MHz Corsair Ram, 3D Club R9 390, EVGA 650GS Psu, NZXT S340 Case, D-Link 1200AC WiFi Card, HyperX 240gb SSD, 2tb WD HDD, Windows 10 64 Bit
https://linustechtips.com/topic/490552-rechargeable-batteries/#findComment-6581024
