Hey does anyone have a tripod for their phone that they can recommend? I'll be using it for my YouTube videos and It'll basically be placed on my table top, so it doesn't have to be over 1 foot tall (12 inches) and I'm willing to spend 20 dollars give or take. Links are appreciated, thanks!
https://linustechtips.com/topic/490489-phone-tripod/
I haven't used one but the Gorillapods are pretty sweet. Under $20 and they can double as a normal tripod or a mount you can attach almost anywhere.
One of these guys:
Desktop: i5-6600k w/ be quiet! Pure Rock cooler. | Gigabyte GTX 1070 Gaming G1 | ASRock Fatal1ty Z170 Gaming K4 mobo | Patriot Viper 16GB DDR4-3000 | 240GB Sandisk SSD | Corsair 500r Case (White) | HTC Vive!! | Shitty Insignia monitor
Peripherals: Razer BlackWidow Chroma | Logitech G502 Proteus Spectrum | Sennheiser 558
Phone: Nexus 5x
Tablet: Amazon Fire tablet (2015)
https://linustechtips.com/topic/490489-phone-tripod/#findComment-6591122
One of these guys:
I have one already and I think these are the best bet, I am just going to buy a phone adapter to go along with it instead!
https://linustechtips.com/topic/490489-phone-tripod/#findComment-6595503
I got this, the phone mount is removable so you can mount it to a proper tripod / slider etc etc
http://www.amazon.com/GripTight-GorillaPod-Stand-Smaller-SmartPhones/dp/B009GHYMB6/ref=sr_1_2?ie=UTF8&qid=1448444426&sr=8-2&keywords=iphone+tripod
https://linustechtips.com/topic/490489-phone-tripod/#findComment-6595761
That's pretty sweet, I like the phone mount, I already have a gorrila tripod so I'm going to try and find a detachable phone mount like the one you have. Thanks for the help!
https://linustechtips.com/topic/490489-phone-tripod/#findComment-6602007
