So my PC pulls around 400 to 500 watts max when full load. so I'm planning on Getting a UPS. I found a 650va/325 watt UPS from APC and I was wondering if it works on my PC. now I don't need the UPS to give me power for like 10 mins I just need it to shutdown properly when black out starts (it's very common in where I live). I know the question sounds stupid But I really need an advice Thanks!
CPU: I5 7400 | Motherboard: MSI H110M  | RAM: 16GB G-Skill 2400mhz  | GPU:  NVIDIA  MSI Gaming 4G GTX 970 | Case: Tecware Quad | Cooling: Stock| Storage: Kingston 120gb SSD, 1TB Drive ,  | PSU: Seasonic 620 Watt 80+ Bronze Full Modular | Display: Devant 50 Inch Smart TV   |
https://linustechtips.com/topic/490406-ups-capacity-questions/
No, it will need to support whatever max load you have.
So if your system truly pulss 500w (looking at it, it probably pulls 300-400w)
you would need a 1000va/500w UPS
https://linustechtips.com/topic/490406-ups-capacity-questions/#findComment-6576612
Basically if your system is at full load it will trigger the overcurrent protection on the UPS, but if your not doing very high load work it will be sufficient for those kinds of situations. Ideally you want ones that can at least take the full load of your system.
https://linustechtips.com/topic/490406-ups-capacity-questions/#findComment-6576615
after seeing 600 watt UPS I think their too damn expensive I think i'll just get a 600 WATT AVR it should work but I still can't shutdown properly I got a trauma out of it when my windows profile got corrupted -.-
https://linustechtips.com/topic/490406-ups-capacity-questions/#findComment-6576722
An AVR isn't the same as a UPS it just corrects for voltage fluctuation and doesn't provide backup battery power, which unit are you looking at?
https://linustechtips.com/topic/490406-ups-capacity-questions/#findComment-6576742
yeah I know what an AVR is it's just that I also need to upgrade my current AVR it's only around 500 watts. the AVR I'm looking at is the Stavol 1000va http://www.lazada.com.ph/stavol-1000va-automatic-voltage-regulator-619075.html price is around If I convert it to usd about 80 dollars I think
https://linustechtips.com/topic/490406-ups-capacity-questions/#findComment-6576806
Not too sure about that brand but if it is capable of the full 600W you need then it would be good, just be sure to include things like monitors, peripherals and networking equipment.
https://linustechtips.com/topic/490406-ups-capacity-questions/#findComment-6576858
what brand do you recommend for avr's?
https://linustechtips.com/topic/490406-ups-capacity-questions/#findComment-6577142
I'm not too familiar with AVR's specifically but I generally recommend APC, Eaton, Tripplite or FSP for power equipment, not saying the one you have selected is bad I just haven't heard of it.
https://linustechtips.com/topic/490406-ups-capacity-questions/#findComment-6577184
Thanks! will check out those brands in the stores
https://linustechtips.com/topic/490406-ups-capacity-questions/#findComment-6578273
